KB90692
Published: August 31, 2023
Data Service performance may slow down on networks with weak connections
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: All versions prior to 3.5.1
For groov RIOs: 2.0.0 to 3.4.1
For groov EPICs: 3.5.1
For groov RIOs: 3.5.0
On rare occasions, particularly in the following situations, you may observe a degradation in performance of MQTT  (either Sparkplug or String payloads):
  • Networks with weak signals or frequent disconnections (for example, cellular networks)
  • Shortly after the initiation of a network connection
  • Frequent network or MQTT broker failures
