KB90689
Published: October 6, 2023
I/O unit incorrectly reports communication enabled after power cycle
- GRV-EPIC-PR1
- GRV-EPIC-PR2
Firmware for the following SNAP PACs:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
For groov EPICs: 3.4.0 to 3.5.0
For SNAP PACs: R10.4a to R10.4d
For groov EPICs: 3.5.1
For SNAP PACs: R10.4e
After the following events, the I/O unit should report that communication is disabled:
- An I/O unit cycles power.
- The PAC Control strategy tests if the I/O unit is available with the following combination of commands:
Is I/O Unit Ready?
I/O Unit Communication Enabled?
With this issue, if no other commands are run before that combination of commands, the I/O unit may incorrectly report communication as enabled.
