KB90678
Published: September 19, 2023
PAC Manager cannot confirm reboot of E1 or E2 brain boards when installing firmware
PAC Manager (PACMANAGER)
All versions
In PAC Manager, instead of seeing a “Success” message after installing firmware on an E1 or E2 brain board, you may see the status message: “Firmware update completed, but restart could not be confirmed.”
E1s and E2s are automatically restarted after installing firmware, but PAC Manager cannot confirm when the restart is complete.
After installing the firmware, wait about 2 minutes and then inspect the E1 or E2 in PAC Manager to determine if it has finished restarting and to confirm the firmware version. For instructions, refer to the E1 and E2 User’s Guide (1563).
