KB90675
Published: August 31, 2023
Publishing data to MQTT Server may be very slow or may stop
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.5.0
For groov RIOs: 3.4.0 to 3.4.1
For groov EPICs: 3.5.1
For groov RIOs: 3.5.0
In the following situations (which cause frequent reconnections), you may observe that data publishing to MQTT server slows down or stops:
- MQTT Client ID collisions
- Lossy or faulty networks
- High-latency networks
- Unreliable MQTT Server
