KB90657
Published: May 29, 2024
groov EPIC running PAC Control strategy may become unresponsive
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
All versions prior to 3.6.0
3.6.0
If your groov EPIC is running a PAC Control strategy and becomes unresponsive, you may be experiencing this issue if you find messages similar to the following in the kern.log file:
 kernel: BUG: Bad rss-counter state mm:d7279200 idx:0 val:1463
  kernel: BUG: Bad rss-counter state mm:d7279200 idx:1 val:3165
  kernel: BUG: non-zero nr_ptes on freeing mm: 84
  kernel: ------------[ cut here ]------------
  kernel: WARNING: CPU: 1 PID: 18 at /grv-pr1/bld-x11/tmp/work-shared/imx6qnxtio/kernel-source/kernel/rcu/tree.c:2679 rcu_cpu_kthread+0x760/0x908()
Cycle power to the groov EPIC processor.
