KB90648
Published: June 17, 2024
MQTT string protocol fails to write floats to analog outputs, timers, and float variables
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.5.0
For groov RIOs: 3.4.0 to 3.5.0
For groov EPICs: 3.5.1
For groov RIOs: 3.6.0
If you enable the “Use Comma for Decimal Separator” option when you configure the MQTT String protocol in Data Service, when the protocol writes floats to analog outputs, float variables, and timers, the writes will fail. You may see an error message in the log file that indicates a parsing failure, similar to the following message:
ERROR|2023-06-08 10:04:55,978|MqttString.java|713|Parsing value '6,14547729e-03', topic 'abcd/write/cont/Strategy/IO/aPr1TestPt01_ain_' for a float failed.
If possible, disable the “Use Comma for Decimal Separator” option.
