KB90591
Published: August 27, 2024
Open connection is closed after Accept Incoming Communication command
Firmware for the following SNAP PACs:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
Firmware for SoftPAC
For SNAP PACs: R9.4a to R10.4e
For SoftPAC: R9.4a to current
If you pass a COM handle to the Accept Incoming Communication command and the COM handle already has an open connection, it should return a -47 (Already Open) error. However, with this issue, the COM handle is closed, and the command returns a -442 (Could not accept on socket.) error.
Verify that the COM handle is not open before calling the Accept Incoming Communication command.
