KB90536
Published: February 15, 2023
OptoDataLink projects configured with SQL Server 2012 - 2014 display blank area in Configurator
OptoDataLink
R10.5a
R10.5b
If you have an OptoDataLink project that has entries with a Database Type of SQL Server 2012 - 2014 and the project configuration file was created with a version of OptoDataLink earlier than R10.5a, when you load it into the OptoDataLink Configurator R10.5a, the Configurator shows a large blank space underneath the section "and goes to a Database".
Use an earlier version of OptoDataLink.
