KB90528
Published: May 23, 2023
Downloading strategy with E2 I/O unit returns -60 error
  • PAC Control Basic
  • PAC Control Professional
R10.5a
R10.5b
If your strategy has an E2 I/O unit where you configured the analog input points with Offset and Gain through the Add/Set Analog Point window, when you download the strategy, PAC Control returns a -60 (empty stack) error.
In PAC Control:
  1. Right-click the analog input point, select Modify, then uncheck the Send Data check box for Offset and Gain. Click OK to save the change.
  2. In the Powerup chart, use the Set Analog Offset and Set Analog Gain commands for the related analog points
