KB90521
Published: January 29, 2024
OptoDataLink service may crash when stopping links
R10.5a (may affect earlier versions)
R10.5b
When you attempt to stop data links from either OptoDataLink Monitor or OptoDataLink Configurator, the OptoDataLink service may crash. Restarting OptoDataLinkRuntime does not resolve the issue; if you again attempt to stop the data links, the OptoDataLink service crashes again.
After OptoDataLinkRuntime crashes:
- Navigate to the PAC Project installation directory.
- Locate a file named runtime.xml and delete this file from one of the following locations:
- For R10.5b and lower, it is typically in your PAC Project installation directory: C:\Program Files (x86)\Opto22\PAC Project {version}\runtime.xml
- For R10.5c and higher: C:\ProgramData\Opto 22\PAC Project\OptoDataLink\runtime.xml
- Restart the OptoDataLinkRuntime service:
- Open Windows Task Manager and click the Services tab (or start Windows Services).
- Find OptoDataLinkRuntime in the list of services, right-click it, and then click Start.
- Start your links.
NOTE: A runtime.xml file will only exist when the data flows are running.
