KB90520
Published: February 15, 2023
OptoDataLink links may fail to start
OptoDataLink
R10.3a to R10.5a
R10.5b
In OptoDataLink, you may observe that your links won't start. This behavior occurs whether you save (click File > Save) and then run the links (click Run > Start all links), or click the Save and Start All Links button.
This issue is more likely to occur if you've recently upgraded your Windows operating system.
