KB90517
Published: January 6, 2023
Screen blank when viewing Node-RED Dashboard from groov EPIC screen or HDMI display
Firmware for the following:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
All firmware versions when using Node-RED Dashboard version 3.3.0 or higher
Beginning around December 31, 2022, if you opened a Node-RED Dashboard project (from the groov Manage Home page, click Node-RED > Node-RED Dashboard) through either the groov EPIC processor's touchscreen display or an HDMI display connected to it you would see a blank screen.
Contact Opto 22 Product Support.
