KB90510
Published: May 3, 2023
Switching between groov Manage and groov View multiple times on groov EPIC touchscreen may cause restart
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.4.0 to 3.4.4
3.4.5
If you switch between groov Manage and groov View multiple times (more than approximately 10 times) on the groov EPIC touchscreen, the groov EPIC may restart. The restart may occur days or weeks after switching between groov Manage and groov View.
- On your groov EPIC touchscreen, avoid switching between groov Manage and groov View.
- If you must switch multiple times (for example, during development), proactively restart your groov EPIC.
