KB90459
Published: November 18, 2022
Strategy with imported .otg file causes -128 error
  • PAC Control Basic
  • PAC Control Pro
R10.4a to R10.4c
R10.5a
You may have this issue if:
  1. You manually edit an I/O configuration file (.otg) and change a channel name.
  2. You import that I/O configuration file into a strategy without errors.
  3. You save and close the strategy.
  4. You attempt to open the strategy and it report error -128: "Invalid character in Channel name. Valid characters are letters, numbers, and underscore. The first letter must be alphabetic."
If you manually edit an .otg file, before importing it into a strategy, carefully check that channel names start with a letter and have only valid characters.
