KB90438
Published: September 20, 2022
Deleting a gadget in one layout breaks gadget arrangements and ability to select in other layout
groov View running on the following groov EPICs:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
- GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: 3.4.0 to 3.4.3
For all other part numbers: 4.4a to 4.4b
For groov EPIC processors: 3.4.4
For all other part numbers: 4.4c
In groov View Build mode, when you delete a gadget in one layout (for example, Desktop) and you have gadgets in the other layout (for example, Handheld), you may observe the following behaviors when you switch to the other layout:
- Gadget positions are corrupted.
- The other layout may or may not show the corrupted positions, but when you attempt to click on a gadget, groov View may highlight/select the wrong gadget.
