KB90434
Published: August 18, 2022
Data from groov EPIC/RIO reported as stale; groov Manage reports Data Service is running
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.4.3
For groov RIOs: 3.4.0
For groov EPICs: 3.4.4
For groov RIOs: 3.4.1
If you enable Data Services to publish MQTT with Sparkplug payloads, it's possible that an unreliable network connection may create a state where an MQTT client indicates that data from your groov EPIC or groov RIO is stale even though groov Manage indicates that Data Service is running.
If you’re experiencing stale data and groov Manage indicates the Data Service is running, then check the most recent entries in the log.  Entries similar to the following may indicate that the stale data is caused by this issue:
Aug 06, 2022 12:50:52 PM org.eclipse.paho.client.mqttv3.internal.ClientState checkForActivity
SEVERE: <MQTT Client ID>: Timed out as no activity, keepAlive=10,000,000,000 lastOutboundActivity=299,598,952,477,582 lastInboundActivity=299,575,831,773,718 time=299,599,938,656,286 lastPing=299,589,939,165,789
 WARN|2022-08-06 12:50:52,540|MqttSparkplug.java|1023|Broker connection was lost Timed out waiting for a response from the server.
 INFO|2022-08-06 12:50:52,544|MqttSparkplug.java|1637|Next MQTT broker requested.
‚ÄčThis issue may also be present if you are publishing string payloads or you are using OPC UA.
Do one of the following:
  • Manually restart Data Service:
    1. From the groov Manage Home page, click Data Service.
    2. In the Data Service Runtime field, click Disable.
    3. Wait for the Data Service field to report Disabled.
    4. Click Enable.
  • Cycle power on your groov EPIC/RIO.
