KB90400
Published: August 24, 2022
32-bit integers that represent boolean values aren't presented as booleans
- GRV-EPIC-PR1
- GRV-EPIC-PR2
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.4.1
For groov RIOs: 3.4.0
For groov EPICs: 3.4.2
For groov RIOs: 3.4.1
In PAC Control, if you define a 32-bit integer to represent a boolean value, the tag that the Data Service creates should be defined as boolean. With this issue, the tag is defined as a 32-bit integer.
For workaround instructions, contact Product Support.
