KB90394
Published: August 3, 2022
Cannot select an array index on some OPC UA array tags
groov View running on the following groov EPICs:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: 3.4.0 to 3.4.1
For all other part numbers: 4.4a
For groov EPIC processors: 3.4.2
For all other part numbers: 4.4b
If you add a tag from an OPC UA device that is a dynamically-sized array, groov View does not display the boxes where you enter the index:
  • In the gadget's Properties panel, the Array element box is missing.
  • In the Update Tag for Gadget window (in the gadget's Properties panel, click Data Source), the Array index box is disabled.
