KB90386
Published: August 24, 2022
Some tag properties for groov EPIC/groov RIO with Sparkplug B payloads are missing/incorrect
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: 3.4.0 to 3.4.1
For groov RIOs: 3.4.0
For groov EPICs: 3.4.2
For groov RIOs: 3.4.1
When you are browsing for tags (through an MQTT tag browser) on a groov EPIC or groov RIO configured with Sparkplug B payloads, you may observe that the properties for some tags are missing or incorrect. For example, if you are browsing for tags with Ignition Designer, you may see that the engUnit property is blank.
