KB90350
Published: August 24, 2022
Revision: 4.0
MQTT Service may fail to connect (out of memory)
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
  • GRV-R7-I1VAPM-3
For groov EPICs: All versions prior to 3.4.1
For groov RIOs: All versions prior to 3.4.1
For groov EPICs: 3.4.1
For groov RIOs: 3.4.1
You may have this issue if you observe any of the following:
  • MQTT fails to connect to an MQTT service with the error "MQTT Con: watermon java.lang.OutOfMemoryError?: unable to create new native thread.”
  • The MQTT error log has a message such as “Out of Memory exception…”. The service eventually restarts.
