KB90346
Published: July 14, 2022
groov native OPC UA server does not accept connections to localhost
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.4.0
3.4.1
In your OPC UA client, if you specify localhost
as the connection string to connect to the groov EPIC native OPC UA server, when you try to browse for tags, you get error messages. For example, in groov View, if you specify localhost:14840/groov
as the connection string, you get the "OPC-UA Service Error" message.
Change the localhost
part of the connection string to localhost.localdomain
. For example, in groov View, change localhost:14840/groov
to localhost.localdomain:14840/groov
