KB90315
Published: June 17, 2022
Some security certificates are not uploaded
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VPAM-3
- For groov EPICs: 1.0.0 to 2.0.2; 3.3.0 to 3.3.3
- For groov RIOs: 3.3.0 to 3.3.3
- For groov EPICs: 3.0.0 to 3.2.1; 3.4.0
- For groov RIOs: 3.4.0
If you upload a security certificate that has a file extension other than .crt, groov Manage may report that it successfully uploaded the certificate and even display it on the Certificates list, even though the upload failed.
Change the file extension of the security certificate to .crt, then upload the file.
