KB90305
Published: August 27, 2024
Controller unresponsive after attempting to communicate with unreachable Ethernet device
Firmware for the following:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
R10.0d to R10.4e
R10.5g
If your PAC Control strategy contains commands to open communication to an Ethernet device, and that Ethernet device is unreachable, then your controller may become unresponsive. This is more likely to happen if the strategy tries to open communication to the device very frequently or repeatedly in a small amount of time.
Try the following:
  • Comment out OPEN instructions to Ethernet devices that you know are unreachable.
  • Insert longer delays between attempts to open communication to the device.
