KB90292
Published: August 21, 2023
groov View displays unnecessary colon when range indicator gadget is oriented vertically
groov View running on the following groov EPICs:
- GROOV-AT1, GROOV-AT1-SNAP
For groov EPICs: All versions prior to 3.5.0
For all others: All versions prior to 4.5a
For groov EPICs: 3.5.0
For all others: 4.5a
In groov View, when a range indicator gadget is oriented horizontally, groov View automatically displays a colon after the tag label to provide a visual separation between the tag label and tag value. When the range indicator gadget is oriented vertically, the tag values is at the top and the tag label is at the bottom, so the colon is not needed for visual separation. With this issue, however, groov View still displays the colon.
