KB90286
Published: November 18, 2022
Append Character to String command results in -95 info message in the controller’s message queue
- PAC Control Professional
- PAC Control Basic
R10.4c (may occur in earlier versions)
R10.5a
If you specify a 64-bit integer for argument 0 of the Append to String
command, PAC Control compiles without reporting that you can only specify 32-bit floats or integers for argument 0. When you try to run the strategy, you will see a -95 "Data stack is not empty" Info message in the controller's message queue.
For argument 0, only specify a 32-bit integer or a float.
