KB90237
Published: November 18, 2022
PAC Control allows duplicate IP addresses when using E1, E2, and G4EB2 I/O units
  • PAC Control Professional
  • PAC Control Basic
R9.6e to R10.4c
R10.5a
When configuring an I/O unit in a PAC Control strategy, PAC Control does not prevent you from applying the same IP address to separate E1, E2, or G4EB2 I/O units in a strategy.
In PAC Control, double-click the I/O Units folder in the strategy tree to be able to see the IP addresses of all the I/O units to make sure they are unique. If there are any duplicates, they will need to be changed in the strategy; the physical I/O unit will need to have its IP address changed as well.
