KB90226
Published: June 17, 2022
PAC Control engine may not start the 64th user task
FIrmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 3.4.0
3.4.0
On rare occasions, the PAC Control engine may not start the 64th user task. A user task can be:
- A chart
- A called chart
- An alternate host task
- A background download task
- A redundant system supervisory task
Restart the the PAC Control engine:
- Log into your groov EPIC processor with a user account that has system administrator permissions.
- Click Controller > PAC Controller.
- Click Disable.
- Click OK on the message about the running strategy being stopped.
- Wait for the Status field to show Disabled.
- Click Enable.
- Click OK on the message about the CODESYS Controller being disabled.
When
groov Manage successfully restarts the PAC Controller, it displays Enabled in the Status field.
