KB90206
Published: July 6, 2022
MQTT may not scan all public tags after watchdog changes for digital output channels
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001
- GRV-R7-MM2001
For groov EPICs: 3.3.0 to 3.3.3
For groov RIOs: 3.3.0 to 3.3.3
For groov EPICs: 3.4.0
For groov RIOs: 3.4.0
If you are using MQTT on a groov EPIC processor or groov RIO module to scan tags, MQTT may not scan all public tags if there is a change to the watchdog value and the watchdog enable/disable field on digital output channels.
After changing the watchdog value and the watchdog enable/disable field for a digital output channel, restart the MQTT service (from the groov Manage Home page, click MQTT > Restart Service).
