KB90192
Published: June 17, 2022
Gadget pasted to another page has incorrect position/size
Firmware for the following groov EPIC processors:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
groov View on the following:
  • GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: All versions prior to 3.4.0
For all other part numbers: All versions prior to 4.4a
For groov EPIC processors: 3.4.0
For all other part numbers: 4.4a
If you copy a gadget that has a position/size already defined for both the desktop and handheld layouts on one page then paste it to another page, only the position/size for the currently active layout will be pasted. The inactive layout gets a default position/size.
Manually resize the gadget in the alternate layout.
