KB90188
Published: June 17, 2022
FTP "delete" command may not delete remote file
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
2.0.1 to 3.3.3
3.4.0
In a PAC Control strategy, if you use the Send Communication Handle FTP delete command to delete a file from a remote FTP server, the command may fail to delete the file and not return an error.
Repeatedly execute the FTP delete command until the deletion succeeds.
