KB90187
Published: June 17, 2022
FTP "get" command doesn't retrieve an empty file
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
2.0.1 to 3.3.3
3.4.0
In a PAC Control strategy, if you use the Send Communication Handle FTP get command to retrieve a file from a remote FTP server, if the file is empty, the command will fail to retrieve the file and not return an error.
If an empty file must be retrieved from the FTP server, write contents to the file before retrieving it.
