KB90173
Published: April 5, 2022
Channel configured as FastADC, Thermistor: Custom Curve returns invalid data
- GRV-EPIC-PR1
- GRV-EPIC-PR2
1.3.0 to current
With this issue, a channel on a GRV-ITR-12 module that is correctly configured as a FastADC, Thermistor: Custom Curve channel type returns invalid data messages:
- In PAC Control, when you inspect the channel, it reports "invalid data" and a quality code.
- In groov Manage, the module or channel page for that channel reports "invalid data" and a quality code.
Use the Thermistor: Custom Curve channel type.
