KB90170
Published: April 5, 2022
groov Manage doesn't display fields to enter Steinhart-Hart coefficients
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
All versions
In groov Manage, when you are configuring a GRV-ITR-12 module and you select FastADC, Thermistor: Custom Curve for the channel type, groov Manage does not display the fields to enter the Steinhart-Hart Coefficients.
