KB90164
Published: August 8, 2024
“Send Communication Handle Command” returns incorrect or generic error codes when an FTP command fails in SoftPAC
R9.3a to current
If you have successfully opened an FTP session with a remote FTP server using a communication handle in your PAC Control strategy, you may receive incorrect or generic error codes from “Send Communication Handle Command” in SoftPAC when the following FTP commands fail:
- get to retrieve a remote file
- appe to append to a remote file
- size to get the size of a remote file
- delete to delete a remote file
- cd to change the working directory
- dir to retrieve a directory listing
- mkdir to make a directory
- rmdir to remove a directory
