KB90112
Published: March 29, 2022
WiFi configuration changes don't take effect until after power cycle
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov RIOs:
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
- GRV-R7-I1VAPM-3
groov EPICs: 3.3.0 to current
groov RIOs: 3.3.0
groov RIOs: 3.3.1
After you save changes to your WiFi settings, you may see either of the following issues, even if the recently saved settings are correct:
- WiFi won't connect.
- WiFi connects and reports the recently configured SSID; however, it is actually connected to the previously configured SSID with the previously configured encryption type and key.
After changing WiFi settings, cycle power to the groov EPIC or groov RIO.
