KB90109
Published: June 17, 2022
In Build mode, unable to open an Event for editing
Firmware for the following groov EPIC processors:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
groov View on the following:
- GROOV-AT1, GROOV-AT1-SNAP
For groov EPIC processors: All versions prior to 3.4.0
For all other part numbers: All versions prior to 4.4a
For groov EPIC processors: 3.4.0
For all other part numbers: 4.4a
In rare instances, while in Build mode, when you click on Edit to edit an Event, nothing happens.
Contact Opto 22 for further instructions.
