KB90096
Published: March 9, 2022
SoftPAC: FTP dir command may return incorrect entries
Firmware for SoftPAC
All versions Prior to R10.4d
R10.4d
In PAC Control, when you use the FTP dir command with SoftPAC, you may see the following issues:
  • The return value may be more than the actual number of entries returned.
  • When the entries are written into a table, some entries may span multiple table elements.
