KB90073
Published: December 14, 2021
The Open Outgoing Communication command cannot create new directories and files at the same time
Firmware for the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.3.0 to 3.3.1
3.3.2
In a PAC Control strategy, when you use the Open Outgoing Communication command and specify a file and directories that do not exist, the PAC Control engine should automatically create them. With this issue, neither the file nor the directories are created and you will see a -70 error in the message queue.
