KB90070
Published: December 15, 2021
Re-enabling communication to remote groov I/O Unit or groov RIO module may reconfigure channels
Firmware on the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
All versions prior to 3.3.2
3.3.2
In the following circumstances, re-enabling communication to a remote groov I/O unit or a groov RIO module may cause all channels to be reconfigured, which then causes output values to reset:
- A PAC Control strategy running on the groov EPIC processor has already configured a remote groov I/O unit or a groov RIO module.
- The groov EPIC processor loses communication with the remote groov I/O unit or groov RIO module for a reason other than a reboot.
Under the above circumstances, channels should not be reconfigured.
Use the Set I/O Unit Configured Flag
instruction before enabling communication to the groov I/O unit or groov RIO module.
