KB90068
Published: June 17, 2022
groov Manage CODESYS page doesn't show application status or Run/Stop button
Firmware on the following:
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.3.0 to 3.3.3
3.4.0
After you enable the CODESYS Controller in groov Manage, then successfully download and run your CODESYS application, the groov Manage CODESYS Controller page should display the application status (Stopped or Running) and a Run Application or Stop Application button in the Applications section. With this issue, the Applications section remains empty.
Start or stop your CODESYS application through the CODESYS Development System interface.
