KB90048
Published: December 14, 2021
After firmware upgrade, Node-RED nodes may no longer work or Node-RED restarts frequently
Firmware on the following:
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
3.3.0 to current
After upgrading to version 3.3.0 or higher of groov EPIC firmware, you may observe the following issues:
  • Some nodes may stop working. This is caused by certain nodes that compile a C or C++ library when installed. You may see a message like the following in the Node-RED error log:
10 Nov 17:44:43 - [info] Flows file : /home/dev/.node-red/flows.json
10 Nov 17:44:44 - [info] Server now running at http://127.0.0.1:1880/node-red/
10 Nov 17:44:44 - [info] Starting flows
foo - Error: The module '/home/dev/.node-red/node_modules/node-red-contrib-serial-modbus/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 72.
Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
  • Node-RED may restart repeatedly. In the  Status section of the groov Manage Node-RED page, you may see the Status field cycle through the Initializing, Stopped, and Running states.
Delete all the installed nodes and then reinstall them by following these instructions:
  1. Download your Node-RED project to your computer:
    1. From the groov Manage Home page, click Node-RED > Project Management.
    2. Click Download Project. groov Manage creates a project file called node-red.project.zip and then the browser downloads it.
    3. Locate the project file on your device and, for safe-keeping, make a copy of the node-red.project.zip file.
  2. Edit the project file to remove the installed nodes:
    1. Open the node-red.project.zip file in a program that can handle ZIP files (for example, 7-Zip).
    2. Delete all files exceptflows.json, flows_cred.json, and info.json. (To make this instruction clear, you do delete node_modules, package-lock.json, and package.json.)
    3. Save the edited zip file.
  3. Upload the project file and restart Node-RED:
    1. In groov Manage, click the Upload Project button to upload the modified node-red.project.zip file.
    2. Click Start to start Node-RED.
  4. Open the Node-RED editor, or if it is already open, refresh the Node-RED editor.
  5. Reinstall the nodes that were removed.
