KB90026
Published: February 8, 2022
Sort order in groov Find is inconsistent with standard ordering styles
All versions prior to 2.1b
2.1b
The groov Find search results window has 5 columns and the first 4 can be sorted by clicking on the header of the column, but the results may not be listed in the order expected:
- All units with Hostnames that start with a capital letter are listed first, then all units with Hostnames that start with a lowercase letter. The sort order should ignore the letter case.
- The device types are not listed in alphabetical order.
- If you happen to use a private network, the IP addresses from the private network appear randomly on the list.
