KB90020
Published: November 19, 2021
Digital Inputs and On & Off Time Totalization appear stuck
- GRV-R7-MM1001-10
- GRV-R7-MM2001-10
All versions
This issue affects any channel in the range 0-1 that is:
- configured for 5-30 VDC digital input or Switch Input, Powered Digital Input;
- configured with the On-Time Totalizer or Off-Time Totalizer; and
- where the input frequency exceeds the working range,
you may observe the following:
- groov Manage reports quality code 24 and does not remove it when the input frequency drops to within the working range.
- The digital input state is not updated.
- The On & Off latches are not updated.
- The On or Off Time Totalization continues to increase (as long as a toggling input signal is present) but the value is less accurate.
Try one of the following options:
- Change channel type to something else, then change it back.
- Reset the I/O to defaults (from the groov Manage Home page, click I/O Configuration > Reset I/O to Defaults), then reconfigure all the channels and any PID loops you may have configured.
- Reset the module by clicking Restart (from the groov Manage Home page, click System > Restart).
