KB90015
Published: May 23, 2023
Move to Pointer Table Element command in OptoScript block generates invalid error
  • PAC Control Basic
  • PAC Control Professional
All versions prior to R10.5a
R10.5b
PAC Control supports specifying a pointer variable as the object (argument 0) of the Move To Pointer Table Element instruction. This works correctly with action blocks; however, in OptoScript blocks, the correctly written code (for example, arrpTable[0] = pInteger;) generates an error and suggests that you rewrite the code incorrectly (for example, arrpTable[0] = &pInteger;).
