KB90003
Published: October 27, 2021
Get I/O Unit Quality command does not report modules with a quality code
  • GRV-EPIC-PR1
  • GRV-EPIC-PR2
All versions prior to 3.3.0
3.3.0
In PAC Control, the Get I/O Unit Quality command should report modules that have a quality code. With this issue, the command does not report modules with quality codes, even if a module has a channel reporting a quality code.
Update your PAC Control strategy to check for quality errors at the channel level with the Get I/O Channel Quality command.
