KB89985
Published: November 2, 2021
Adds, deletes, or edits to computed tags disappear from Configure Tags dialog
groov View running on the following:
  • GRV-EPIC-PR1, GRV-EPIC-PR2
  • GROOV-AT1, GROOV-AT1-SNAP
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.2.2
All other products: R4.3d
GRV-EPIC-PR1, GRV-EPIC-PR2: 3.3.0
All other products: R4.3e
In groov View Build mode, after you add, edit, or delete a computed tag, the changes made to that tag disappear after closing and re-opening the Configure Tags dialog.
