KB89974
Published: October 27, 2021
For a temperature input channel, the Calculate and Set Offset/Gain area of memory map does not calculate the correct offset
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.0.0 to 3.2.2
3.3.0
If your groov EPIC I/O unit is configured for °F, the offset calculation for a temperature input channel is incorrect in two ways:
- The offset value returned is 5/9ths of the expected value. (However, the values stored in the corresponding Analog and Digital Configuration area are correct.)
- The offset applied to the temperature input channel is 9/5ths the expected value.
Configure the I/O unit for Celsius (°C) and then calculate and set the offset.
