KB89973
Published: October 27, 2021
For temperature input channel types, offset calibration parameter may cause incorrect adjustment
- GRV-EPIC-PR1
- GRV-EPIC-PR2
3.0.0 to 3.2.2
3.3.0
If you configured a groov EPIC I/O unit for °F and you enter a non-zero value for calibration offset on a channel configured for temperature input, the offset value used in calibration calculations is 9/5ths greater than what you entered.
Set the I/O unit to °C, then enter a value for the calibration offset in °C. Switch the I/O unit to °F. The value will be correctly adjusted.
