KB89963
Published: February 8, 2022
Reconfiguring to another scalable subtype may cause invalid channel configuration
PAC Control Basic
PAC Control Professional
R10.3d to R10.4a
R10.4b
In the Configure RIO Channels dialog of PAC Control, if you change the channel type of a channel on a universal I/O module (see list below) from one scalable type to another scalable type, the change may cause the scaling values to become invalid.
  • GRV-MM1001-10
  • GRV-R7-MM1001-10
  • GRV-R7-MM2001-10
Change the channel configuration through the Edit Analog Point window.
