KB89953
Published: February 7, 2022
Moving a groov analog I/O channel to a GRV-MM1001-10 may corrupt channel's configuration
- PAC Control Basic
- PAC Control Professional
R10.4a
R10.4b
In PAC Control Configuration mode, if you move a groov analog I/O channel to a GRV-MM1001-10 channel position that does not support the exact same analog I/O configuration (including type and feature), PAC Control configures the channel on the GRV-MM1001-10 module with an invalid configuration. You may observe that:
- On the GRV-MM1001-10 module, the analog channel is redefined as a digital channel.
- If you try to edit that channel, PAC Control opens the Edit Analog Point window, which is for configuring analog I/O.
